Add Copy as... Right click to Edit Menu bar?
I’d love it if the commands in the right click contextual menu were available in the Menu Bar under edit, so we can assign shortcuts via MacOS. I like to copy as Markdown a lot, and being able to map my own shortcut, or have one included would be great, but as far as I know there’s not reliable way to map that action to an app specific right click menu option. (I’m happy to be proven wrong.)
Thanks!
Plus one for this.
Right now you can use control + return to open the context menu with keyboard shortcuts as a partial workaround
@mlw Thanks for sharing that. Lamentably, it still leads to using the mouse, as arrow keying through all the menus is even more tedious than simply right clicking, and unfortunately the way it’s rendering the menu seems to make it impossible to setup an AppleScript to run it. Guess I’ll just hope it’s added.
