Append to... / Prepend to... does not work in SHARE extension
I am using the latest version of BEAR V2. And I have found that I cannot “append to” or “prepend to” when using the SHARE extension to send data to BEAR.
I can use the extension. This does work. But clicking on either of these 2 buttons there is no reaction… nothing happens…
/Wolfgang
Yup, there’s been a discussion started on this. Hoping there will be a fix soon.
V2.0.1 which fixes this issue has been released. Should appear on your device soon.
:grinning: :clap:
It’s arrived…
everything working as it should do. Yahoo!!
