My text is still flickering (I’m assuming it’s related to when opening different notes, the note is scrolled down/up and it looks like content is missing)
Please check the latest Test Flight update (12671) for macOS and let me know if you still experience those problems.
I also experienced the flickering issue and installed version 12671 this morning. I just encountered a pretty heavy case of the flickering issue. I captured part of it with a screen recording. I can send it to you by email (for privacy reasons) if it would be helpful.
Would also love to test. Need the code if possible. thanks!
From a brief test, seems to be gone now. Thanks.
One minor UX feedback bit: the chevron for toggling folding seems to be bottom-aligned with the text, making it look a little different for each level of heading.
Could centre vertical alignment be a consideration for placement?
Just a thought, love the feature!
ScottyJ
Can you please send a screenshot of this issue?
Can you please check build (12678) regarding this issue and let me know if you see improvements?
I sent it to you in DM!
You bet, here is a screenshot showing the chevrons relative to different headings. If it matters, this is on a MacBook Air M3 15" running macOS Version 14.5 (23F79).
Would love to help test. Any Testflight invitations available?
