Bear 2.6.7 Beta release
Bear 2.6.7 is now available on TestFlight for both macOS and iOS.
We don’t usually write posts here for bug fix updates, but this one includes a lot of UI fixes for iOS 26, and we want to ask you to stress test it as much as you can and report if you see Bear’s interface not behaving as expected.
If you are running a previous iOS release, please check if everything works as usual.
Thanks for your testing!
## macOS
- Window titles in detached notes now update correctly when renaming a note
- Fixed an issue where removing a selected sidebar tag could reopen the Notes list when it was closed
- Improved support for appearance changes triggered by Shortcuts
## iOS
- Home Screen long-press actions now respect the “Start New Notes With” preference
- Fixed an issue where the purchase panel did not appear when non-Pro users tried to enable app locking
- Improved password field layout to remain visible above the keyboard
- Fixed an issue that could cause the cursor to appear in an incorrect position
- Resolved various user interface issues
- Fixed missing localization in Control Center widgets
## coreOS
- Fixed a crash when deleting rows or columns in tables
- Improved rendering of nested callouts
- Fixed localization issues in Korean, French, and Italian
- Location widgets now correctly reflect pinned items within tags
- Fixed an issue with Base64 images in the Markdown exporter
