how do we get added? please add me mods, thanks!
Really looking forward to this beta as well. Need to move some tables from notion so be a good test
Would love to be part of the beta as well !
I would like to participate in the beta testing, too.
Would really appreciate an invite too, thanks!
I would be happy if I could participate in the beta as well.
Would appreciate an invite to the beta as well.
Please add me to the beta
Please add me to the beta as well!! YAY
I would like to join beta as well.
What if we want to keep the Bear 1 in place? Bear 2 is called the same (“Bear.app”) so macOS will prompt us to overwrite the current one. Should we choose the “keep both copies” option when prompted?
Yes, the Bear 2.0 will be renamed as Bear copy. Or you can rename the app whatever you like.
Hi! I’m excited to try the beta as well. Thank you!
Excellent. Thank you!
I’d also love to get access to the Bear beta!
Thanks a lot. Hope to test soon
Excited to try the next batch as well
I’d also love to be part of the Bear2 Beta!
Hey folks! I couldn’t joint the mailing list for beta access for some reason, it said “there are errors below”. Is there a known fix? Thanks!
I would love to be part of the beta too. Beta tested Panda too.
