Bear forgets window site/position (possibly related to snap tiling in macOS sequoia and later)
  • Bear Version: Version 2.6.6 (13972)
  • OS Version: macos 15.6.1 (24G90)
  • What were you doing: on laptop, I once used snap tile to resize Bear to near-full-screen (drag-hold against screen top). Later, on a big external screen, that near-full-screen was wayyy to big. I sized Bear window down a reasonable size (say, 1/3 or screen width/height). I quit Bear, then restarted Bear.
  • What happened: Bear opens near-full-screen again
  • What did you expect to happen: Bear remembers the window size and position I set it to.
This appears to be Sequoia snap tiling on macOS rather than Bear forgetting state. MacOS recognizes the window as a tiled scene when you drag-hold to the top, and Bear restores that tiled geometry when relaunching rather than requiring a manual resize.
When moving between laptop and external displays with differing scaling, I’ve noticed this on 15.x with various AppKit apps. Simple workaround: move the window slightly, resize without snap tiling, and then exit Bear. macOS typically drops the tiling state as a result.
The reason for my bug report was that the workaround you mention doesn’t work for me — even when moving and/or resizing (and other things to nudge Bear to reassess its window state), Bear on the next launch still snaps back. I should have added that for clarity, thanks for pointing out.
Still happens under the current Sequioa 15.7.3 and also still not resettable by sizing, moving, etc. Bear is also the only app that I can get to show this behavior.
I’ve also experienced this issue on 15.7.3 and its driving me a little crazy. Not only is the main app never positioned where I last left it but also notes opened in a new windows.
I’m able to simulate this behaviour, but it seems all the apps are affected here.
What I’m seeing is:
  • If I’m tiling any app near full screen, “detach it” by dragging the top, quit and reopen, the app reopens with the last position/size.
  • If I’m tiling any app near full screen, resized horizontally, quit and reopen the app opens near full screen.
@trix180 I can confirm this behavior locally. Resizing any way doesn’t seem to ‘unmark’ the window state as being near-fullscreen. I didn’t even know this snap-back behavior existed in the first place.
Doing this fixes it for me. Thanks!
For posterity: the workaround is not to move or resize the window, but to drag the title bar down a bit until the window ‘unsnaps’.
