Window doesn't resize correctly when double clicking title bar of tag column
  • Bear Version: 2.3.12
  • OS Version: macOS Sequoia 15.4.1
  • What were you doing: Double clicking the title bar to maximize window
  • What feature did you use: Window resizing
  • What happened: Double clicking the title bar in the first ‘Tag’-column briefly maximizes the window, then resizes back again. Doesn’t happen when clicking the title bar of the other two columns.
  • What did you expect to happen: Window stays maximized
