Bear Web Update 0.24 (2025-10-30)
Here comes our new treat, just in time for Halloween.
Reload the app in your browser to get:
  • Added: Command + backspace now deletes to the beginning of the line on macOS.
  • Improved: Toggling code blocks, math blocks, and callouts works better when nested inside lists.
  • Improved: Backspace and delete inside code blocks maintain indentation inside lists.
  • Removed: The hex color syntax with alpha (#RRGGBBAA) is no longer recognized to reduce conflicts with numbers in text.
  • Improved: session persistence for international accounts
  • Improved: cloud synchronisation
  • fix: delays leading to wrong UI updates when navigating quickly through notes
Since the update, the login with Apple does not work. I always geht an “Authentication error”. I closed the tab, closed the browser, deleted the cookies, and so on. Any idea ?
Kindest regards
Jörn
Hi! That’s interesting, and unexpected. Can you try with an incognito window once, or with a different browser, just to check?
I tried with an inkognito window and it worked. thx for your help. And now it works - after restarting the browser - with the “normal” window too.
