Maybe it’s just me, but I find the way Bear exports block quotes into Word kind of odd/off. I’ve only ever seen block quotes left-aligned. (And in MLA style, the right margin of a block quote is the same as the normal margin.)
We tried to replicate Word defaults for the quote and other DOCX styles but I don’t know if there are some kind of regional defaults based on the device locale.
Is there some way to customize the defaults/template? My use case, which is for scholarly writing, (sadly) requires frequent exporting into Word. I can manually change the styles every time I export, but it would be great to customize the Normal/Quote/etc. style templates for the format I typically need.
No. We want to give export options at one point but at the moment it’s not possible to change docx styles
