Version 1.9.6 (9044) and Version 2.0 (9695)
What were you doing: Changing the theme in Bear 2.0
What happened: This also changed the theme in Bear 1.0
What did you expect to happen: I expected this to only affect Bear 2.0
Hi,
unfortunately, this is a side effect of using the same User Defaults keys in both B1 and B2. We don’t have a good solution for this at the moment because the final release will use those keys.
