Bug: indentation for nested callout (Bear and Lettera)
Bug in Lettera and Bear
  • Bear Version: Version 2.9.1 (14638)
  • Lettera Version: Version 1.0.0 (4178)
  • OS Version: Tahoe 26.5.2 (25F84)
  • What were you doing: Using an indented callout/quote
  • What feature did you use: Callout/quote, indentation
  • What happened: Second and later lines are not indented properly
  • What did you expect to happen: Second and later lines to be indented properly and fully contained within the quote/callout
Minimal reproducible examples:
And pasted in a code block here for convenience:
1. Alpha
   1. > [!NOTE] Bravo
      > Charlie
2. Alpha
   1. > [!NOTE] Bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo bravo
      > Charlie
