Hi,
how do I change the default search engine in Bear? It would be nice to be able to not have to use google.
Hi,
I think that is a system-wide menu item that uses whatever you have set as your default search engine in Safari. I have mine set to DuckDuckGo and that’s what shows up in Bear when I right click.
Thanks for that.
It appears to be a Mac problem. Even though I’ve never used Safari and have Zen set up as my default browser the menu seems to take every thing from Safari.
I opened Safari and changed my default search engine, and it works now.
I just have to find out how to get it to use Zen (which is set as default browser) instead of Safari.
