Bear Version 2.1.8 (12568) Telegram 10.10.1 IOS 14.4.1
Paste emoji from bear to telegram gives gibberish characters, every other app works as expected.
Happened since the last IOS Update. Works on Sonoma and others apps on iPhone
Is Telegram the only app reporting this issue? If you paste on Notes do you get the correct result?
Yes…Paste to Notes and other apps work as expected.
Thanks. I suspect something wrong with Telegram pasteboard management. I checked Bear’s code but we are not doing anything particularly strange.
Thanks for checking. Weird thing is that paste from Notes etc to Telegram all work…Just Bear has this behaviour.
