Just want to add that this bug is actually really painful. It makes it really difficult to actually use Bear for writing and then move text to other places where other people need to see it, which is a super common use case.
Yes, something odd is definitely happening here but I’m confused because I don’t get the result shown here (but another which might not be desirable as well).
But should there be a leading tab on first list item as well?
I assumed that a round trip: Copy As → Rich Text and then Paste From → Rich Text, inside Bear itself, would be the litmus test that those two are working correctly?
Anyway, copy and paste into Word and Pages seems to work correctly.
Here are 3 copy rich text & pasting examples. In every case, notice that it’s not actually pasting rich lists. It’s just indented dots and dashes that look pretty bad (except in Slack, the top level bullet is a rich bullet, but the sub-bullets are not).
Looks like with Bear2 testflight, i can’t install Bear 1 anymore without uninstalling and losing my recent data. Any updates on getting the format working would be great!
I have just finished a fix for this issue but I must provide some context. My testing is based on the rich text copying from Bear to GDocs (Chrome), TextEdit (RTF mode), Slack, Pages, and Word.
Word seems to not manage the RTF lists very well or not as the other apps. You can try making a multilevel list in TextEdit and paste it into Word to see the results. I’m aware the above used to work in Word with Bear 2 but I’m not able to have it work for the other apps and Word. This is what concerns me the most about the fix but I have to rely on user feedback. Bear 1 kinda works if you don’t use deep multi-level lists.
Results for other apps are coherent with the original list but some replace the list items (circle, square, dot, …)
