Trying to put in a footnote What feature did you use:
Footnotes What happened:
The editor crashed What did you expect to happen:
Not crashing
I had this also. I was attempting to create a footnote, by placing [^1] at the end of a sentence, and then [^1]: at the end of the document. As soon as I entered that colon the app crashed. Replicated the same crash a second time, also when I entered the colon.
Testing version : Panda 1.0 (362)
What were you doing : I was attempting to create a footnote, by placing [^1] at the end of a sentence, and then [^1]: at the end of the document.
What feature did you use : Footnotes
What happened : As soon as I entered that colon the app crashed. Replicated the same crash a second time, also when I entered the colon.
What did you expect to happen : This is how Iβm used to creating footnotes in Markdown, so I was hoping it would make a footnote. Perhaps thatβs not the implementation in Bear?
The footnotes apparently do not work. Wrong code?
Footnote with Panda^ [because of wrong code?] and a footnote with Markdown - here iA Writer [^ works perfectly].
