Customize bear iphone widget
Hi,
I like the Bear lock screen widget on the iphone that allows quick creation of a new note.
It’s useful for jotting down a quick thought in the moment, but I would like to be able to categorize these notes and separate them from other notes. Would it be possible to add a separate tag (e.g. #quicknote or simiilar) to these notes, to separate them from the others?
You can do that today. Create a simple shortcut with text entry, which then automatically tags your note, and put it in a widget.
