Embedding MP4 files produces a link rather than showing an attachment
  • Bear Version: Version 2.8.1 (14428)
  • OS Version: MacOS 26.6 Beta (25G5028f)
  • What were you doing: Inserted an MP4 file
  • What feature did you use: Drag and drop, as well as Photo browser. Same behavior
  • What happened: A markdown link was created, followed by an HTML comment “{“embed” : “true”}”
  • What did you expect to happen: The file is attached to the note and an attachment box is placed with the file name and file type
This is what I see now:
The note list preview displays correctly:
This is a file I created in the past, showing the correct behavior:
Thanks for reporting this issue. Is this happening regardless of the MP4 file you drop in Bear?
Ah, I figured it out. The file name contains a “%” which seems to affect the behavior. Something about iCloud storage pathing maybe?
Yes, this seems to be the case! Thanks for your feedback.
