Encoding issues Bear → Telegram
  • Bear Version: 2.4.5.
  • OS Version: iOS
  • What were you doing: Pasted from Bear to mobile Telegram app
  • What feature did you use:
  • What happened:
  • What did you expect to happen: readable text
    Hi! I am a small scale Bear Evangelist. During my seminar on creative writing I usually recommend the app. Recently one of my students told me that after copying from Near to Telegram messenger on her iPhone she gets the gibberish encoding (update: it concerns Cyrillic symbols).
    I checked it and yep, same happens on my iPad. Any advice on how to fix that ?
Important: those are Cyrillic (Russian) symbols, English symbols seem to transfer just fine
I have tried to reach Telegram developers about this issue multiple times without success.
Everything works as expected on our side, but VK/Telegram encoding of Cyrillic characters seems to be non-standard.
At the moment, to avoid this issue, you can use Paste From > Plain Text in Bear.
Thank you very much!
Yep, unfortunately they are not communicating well :confused:
