I really love using bear and was so excited to see tables being introduced in this beta! I have an issue though when I’m creating a table with many columns, it does not expand. Let’s say I want to have 10 columns, every time I add a new one the columns get smaller and smaller instead of expanding
I use Dropbox Paper for work and I like how you can expand their table to the full width of your screen and it allows you to scroll to the right if you have lots of columns. This would be really helpful if you could do that in Bear!
