Ghosted Lines after text selection
Testing version: Version 2.1.1 (12375) on Mac
What were you doing: selecting text
What feature did you use: basic text selection by click/drag and triple click
What happened: when the text is deselected it leaves a ghosted line across the note, that only disappears when the note is closed and reopened (see attached screen capture)
What did you expect to happen: the text would just be deselected and return to normal
Summary
This text will be hidden
This kind of glitch is unfortunately very hard to address. Please tell me if you are experiencing this on a retina monitor and the macOS release you are running.
Thanks for taking time to respond even though it’s a difficult issue to address. I’m running macOS 14.3 (23D56), and I’m experiencing the issue on all of the various displays I use including the laptop display on my 16" M2 Pro (3456x2234), my older 24" Dell monitor (1920x1200), and my 12" M1 iPad Pro (2048 x 2732) when used as an external display.
