- Voice notes directly in Bear note, just like Apple Notes.
- The new customizable floating bar with no line (so it doesn’t look like a horizontal column) instead of the BIU (or in addition as an option).
- Custom themes.
- Resizable UI, iPadOS 26 now supports resizing the columns across apps such as Apple Notes, Voice memos, the Files app, etc. I think the note list column is too wide in Bear for iPadOS.
- SF Pro font support.
- Ability to write with Apple Pencil without having to add the square, would be cool if it can do it non-destructively so you can scratch words you wrote with your keyboard, draw stuff and write next to it, and the infinite possibilities you can with real paper.
Cheers!
