I’d like to use Bear but I need to be able to import my notes from Amplenote. It exports notes with YAML front matter metadata, specifically the tags. It exports attachments in a folder called “attachments”. I’ve been searching for how to import this into Bear. Using the “Import from Markdown Folder” doesn’t produce an acceptable import. Any tips would be appreciated.
we don’t have an importer specifically designed for Amplenote but I think the Obsidian one might work. Please give it a shot.
Same. Looks like I’m out of luck unless I want to hand tailor 2000 notes. Here’s a sample:
