- Bear Version: 2.6.3
- OS Version: macos 26.0.1
- What were you doing:
- What feature did you use:
- What happened:
- What did you expect to happen:
The search and create new note buttons at the top of the note list disappear, and the tag text is dimmed
I’m running into the same issue. I have to restart the app in order to see the Search and new note icon again
Same here, need to restart the app
Hey everyone,
We’re aware of this bug and have already fixed it in our internal build, the next update should take care of it!
In the meantime, you can click where the Search or New Note buttons were and they’ll reappear. The issue is related to an animation not cleaning up properly.
Thanks for your patience!
