PDF preview of horizontal pages has wrong aspect ratio
  • Bear Version: 2.6.6 (macOS) / 2.6.5 (iOS)
  • OS Version: macOS 13.7.8 / iOS 26.1
  • What were you doing: Adding a PDF with horizontal pages to a note.
  • What feature did you use: PDF preview / Preview of PDF files.
  • What happened: The preview shows the page as a vertical page with a lot more white space above and cuts off of the page on the long side.
  • What did you expect to happen: The preview of the PDF shows the content of the PDF in the correct aspect ratio.
Screenshots macOS
Because I could not put more then two images in a post as a new user, here are the screenshots for this issue on iOS:
