With the latest iPadOS and Bear versions (using a Pencil Pro in case that matters):
- Open a drawing in Bear with your Pencil.
- Doodle. Then select the selection tool with the squeeze gesture
- Select something, move it
- Select another tool
- Despite having another tool selected, the selecter pen remains active. You need to get out and back into the drawing to get normal access to other pens back.
