Printing a note with blue links print those in (hardly visible yellow)
Printing a Bear note from Mac OS 15.4.1 to a HP ENVY Photo 7134 results in hardly visible yellow links i.s.o. the blue ones as shown on the screen. Is there a setting to change this or is it a bug>
I’m pretty sure this is an issue with the printer, but the links should be red when using print in Bear.
The links show blue in the document in Bear and yellow (hardly visible) when printed. Printing a PDF, created in Obsidian, prints the links blue. Nothing wrong with the printer in that case. Would like to have this sorted out before I make the license definite before April 30th
Checked again, but it is as follows:
  1. the links in Obsidian are in black
  2. importing them, with the Bear importer, colours them blue
  3. printing the note with the HP ENVY Photo 7134 printer, the links come out yellow
  4. printing the note from with “colour off" settings, makes the colour of the links grey (and not blue and not red)
  5. exporting the note from Obsidian to PDF, the links stay black and are printed as such
So if somebody else in the Bear Community had the same issue and solved it, I would like to hear about that.
Thanks
