If I export a Bear note as markdown (.md) spotlight search will not find anything searches within the file. However, if you export as .txt it works great. And, if you rename extension to .md it still finds text inside the file.
Does anyone know what (if anything) is different when Bear exports as markdown and spotlight will not find any of the contents.
I’m coming to that conclusion. I tried all sorts of things but the search never worked. I thought since the .md file was a text file it would index it and that I had some settting or something else wrong.
I had been hopeful for using a future Panda to be able to use spotlight in that way.
This is weird, Spotlight should index markdown files if you have an app that declared .md as a text-base file. I’m currently able to use Spotlight to search for .md files
My suspicion is that you have installed an app that not declaring .md files correctly. If you want, you can use this command in Terminal.app and check how the .md files are seen by your system:
mdls yourfile.md
If you can paste the output here I can check what’s going on.
I am using iOS. As I mentioned, I tried all sorts of things and one strange thing is that if I exported a note as Markdown then spotlight will not recognize it and hence search will not find anything within the file.
But, if in Files I duplicate that file then spotlight will find whatever search term within contents as expected.
That is why I was asking if a .md file were different when Bear exports it.
The reason any of this came about is I was testing some ideas for future use of the iOS version of Panda using .md files and being able to use spotlight to search.
I was just exporting some notes from Bear in Markdown format and then trying out using spotlight for searching.
Ran into the same issue. MD files weren’t being indexed by Spotlight. Lots of results on Google suggested Spotlight simply doesn’t. This thread mentioned making sure they are being set as a text type and a terminal command to confirm that. Checked and it was so that wasn’t the issue. The issue is checked and .md files at least on my machine are being encoding as ASCII, UTF-8 which Spotlight prefers. Converted a sample file, " iconv -f us-ascii -t utf-8 sample.md > ~/Desktop/sample.md" And voila, spotlight immediately could pick up. So you’ll just need to do batch re-encode them to UTF-8.
