Hi,
I have two suggestions for panda:
- Support typing “/” to list and quick access the abilities of panda, like what Confluence does.
- Make “Table of Contents” can be fixed on left or right side in the editor page, like what Google docs does.
Looking forward to have panda in Bear App.
Thanks
Colin
Hi there Colin,
I can see that this is your first post on the forum, so welcome to the community!
Thank you for taking the time to provide us with some feedback. I will pass it onto the team.
Regarding the second point, at the moment in Panda after you open the Table of Contents, if you pull off the panel it will pin it.
This panel can then be dragged around to the position you desire, hoping this helps!
Thanks for your reply.
For the second point, I tried and it works as you said. My advice is that it is better the editor panel has ‘Table of Content’ inside it on the right side (not floating on it).
Thanks
Colin
I also prefer the ‘in-window’ design over the floating one. The iPad version of the info panel of Bear is what I prefer the most.
Hi Colin,
Thank you for your clarification and suggestion, I’ll pass it onto the team
Thank you for the feedback Eleanor
