The rendering for link previews is kind of buggy
  • Bear Version: 2.2.1
  • OS Version: Sonoma 14.5
  • What were you doing: Turn a text URL to preview mode
  • What feature did you use: Link Preview
  • What happened: Part of the text has been “cut off”
  • What did you expect to happen: The entire text should be rendered perfectly
This is how it looks like:
Here are my settings for typography:
It’s a tiny bug, but it’s kind of annoying.
Hope this can be fixed in the near future.
Hello, and thanks for reporting this issue.
Do you mind posting here the full link to the “Shark EVOPOWER…”?
Sure, Here is the URL I’ve been used:
https://direct.sharkninja.jp/products/lc351j-4861ch200j
Additionally, Things get worse if you use some pages which are Chinese or Japanese:
(URL: https://zenn.dev/uttk/articles/bd264fa884e026)
Hello :wave:
I updated to 2.2.2 recently and this problem still exists.
Do you have any plan to fix this?
FYI, link preview looks perfect on iOS & iPadOS:
There seems to be a padding issue with the Japanese fonts.
I still have problems with hiragana in tables.
Mentions here:
Tables and non-Latin characters
This is still an issue for me on desktop. (Not using any Japanese fonts.) My font size is set at 22pt; text in preview links only stops being cut off if I drop the size to 16pt.
