I’m a new (potential actually) Bear user and I was excited to learn that it now has mathematical typesetting support. However, immediately upon trying the feature I encountered several problems.
- Math doesn’t render in Markdown tables. Neither inline math $…$ nor display math $$…$$ produce any typesetting inside tables.
- Display math with the $$…$$ and the formula on a single line doesn’t produce any typesetting.
See attached screenshot for illustration of issues 1 and 2.
- Large-ish files with a lot of mathematical typesetting are very very slow to scroll. The bigger the file, the slower the scrolling performance. As an example, I attempted to import a file, which according to Bear contains 5176 words and 32620 characters (original Markdown file was about 34 KB), and the performance was so slow as to be completely unusable.
- Bear Version: 2.6.3 (13844)
- OS Version: Tahoe 26.0.1 (25A362)
- What were you doing: Trying to use math typesetting in Bear.
- What feature did you use: Math typesetting.
- What happened: I encountered two parsing problems and one performance (scrolling) problem.
- What did you expect to happen: I expected math to be typeset and scrolling to be smooth.
