UI issue with note list for a particular tag
I have a long-standing issue with the list of notes for a particular tag.
As you can see, there is often a large gap between notes in the note list.
Sometimes, one note is partially obscured by another note.
In the above screenshot, you can see that the middle note underlaps the top note.
The issue tends to stop when I switch to another tag and back, or when I scroll up and down using my trackpad.
(I do typically to navigate the notes in the list with the directional keys on the keyboard.)
I have noticed this on MacOS only. Not iOS.
I’m using Bear Version 2.6.3 (13844), but I have experienced this issue for many months.
I’m using the latest version of MacOS (26.1 [25B78]), on a MacBook Air M2.
