Undo Doesn't Work
Operation system: Windows
Web Browser: Chrome (131.0.6778.265)
What were you doing: Deleted some text and wanted to undo it.
Used the regular ctrl+z shortcut
(copy and paste shortcuts work fine, just looks like undo doesn’t work)
Undo didn’t work, text was gone forever
Undo to … undo.
I am unable to repeat this problem. Does it happen often and can you repeat it? Can you give an example when it happens or even record a video?
Like the native app, if you move between different notes, the undo buffer is lost when reopening a note. Is this what happened?
Frustratingly I can only sporadically replicate this. Happened a while back, and then had it the other day consistently across a couple of notes.
Just for clarity the issue occurs in a single note, without switching between notes or changing anything.
If it happens again I’ll see if I can record it (will also need to work out how to record things on windows :rofl:), or ideally get a reproducible.
I have been able to repeat it. We are working on a fix.
