Undo button not working on iOS
  • Bear Version: v2.8.2 (14473)
  • OS Version: iOS 26.5
  • What were you doing: Entering text or making changes to the content within a note
  • What feature did you use: Undo button (⮐)
  • What happened: The typed text / formatting changes aren’t undone. Sometimes the text will highlight itself sporadically.
  • What did you expect to happen: Any changes should be reversed.
I made a recording showing the bug in action. Note, it’s only the on-screen button that doesn’t function properly, using the keyboard shortcut ⌘Z works as expected… although this isn’t very helpful since the bug occurs exclusively on my iPhone (I used iPhone Mirroring to record my phone’s screen which is how I was able to test the keyboard shortcuts were working). I also can’t replicate the bug on MacOS or my iPad, it’s just my iPhone that has the issue.
Genuine bug or is it just my phone being weird?
