I use the Popclip app quite a bit as part of my writing workflow and I’ve been able to use it seamlessly in Bear until recently.
There’s no rhyme or reason why it works some days and not others. I’m hoping that another Bear user who also uses Popclip can clue me in.
To be clear, the way Popclip works is upon highlighting text in whatever app you are in at the time, Popclip will give you a popup menu of icons for a variety of services, from Dictionary to specific search platforms, etc. Presently, I don’t get that pop-up upon highlighting text in Bear, except it mysteriously starts working again at random times.
Any help would be appreciated.
Cheers.
I tested pop clip and made the experience that in some apps (in my case mainly in safari) a selection very often doesn’t open the expected pop up. Seems to be a problem with popclip
I have not had any issues with PopClip in Bear, and PopClip is an app I use/invoke all day long… PopClip has a forum just like this, where you could possibly get help - https://forum.popclip.app/
UPDATE: Classic mistake, I needed to update the Popclip app. Weird though that the malfunction was only Bear. Thanks for the replies.
