Does anyone know how to share a bear note to other Bear user with iOS device?
I know that I can share contents of a note through the share sheet, but it sends just a plain text message. Attachments are not shared. .I have tried to export the note to “Bear note” or Texbundle format and send it through iMessage but the receiver could not open the file with Bear on iOS .
The best way should be sharing .bear files but I suggest using AirDrop instead of iMessage.
Thank you for quick reply.
Airdrop works fine but it’s only available for physically nearby people.
Is it technically impossible to share .bear files through iMessage?
No, but the file has to be moved to Files first and then can be imported by opening the file or in-app via the … menu in the sidebar.
