Wrong quotation mark after an em dash
Testing version: 2.0 (10984) on iPad
What were you doing: Write a sentence starting with a quotation mark and ending in an em
dash and quotation mark. For example: “Then I saw—”
What feature did you use: Smart quotes
What happened: First quotation mark is properly changed to an opening mark, but the second is changed to an opening mark instead of closing. I get this: “Then I saw—“
What did you expect to happen: I expect to get “Then I saw—”
Just to add some context, I want to use Bear mostly to write fiction and an em dash at the end of a dialog is a common convention to signal an interruption in what the person was saying.
Hello and thanks for reporting this issue. We’ll look into this as soon as possible.
