YAML front matter get exported
Testing version: 0.1 (2936)
What were you doing: Export document with YAML front matter.
What feature did you use: Any of the Export formats
What happened: YAML front matter get exported as it is.
What did you expect to happen: YAML should be hidden by default in exports, but with a switch to show it or not (like for #tags)
Yes, YAML is supposed to be metadata so I think it’s safe to assume those should not be reported in the final exports. We’ll provide a fix with next update.
Thanks for the feedback.
