Arrange to-dos on iOS
On macOS, I can drag the to-do checkboxes around, which is very convenient. I expected long-pressing checkboxes on iOS to activate a way to arrange to-dos, but instead, I got the option to save the checkbox as an image :upside_down_face:
Hey,
i use the Bear keyboard for that.
But i think drag and drop is a feature that should be added, if possible.
That’s helpful! Thanks for sharing - I’ll definitely start using that. Drag and drop would still be nice though as well :slight_smile:
interested in this too!
