Auto-logout Issue on Bear Web App
Operation system:Windows 10 22H2
Web Browser:Google Chrome 141.0.7390.123
  1. After logging into the Bear web app (web.bear.app), I was browsing or editing Markdown notes;
  2. The issue occurred even when continuing editing operations (e.g., typing text, modifying formats).
“Note Editing”, “Real-time Sync” features of the Bear web app, and the basic “Login Session Persistence” feature.
  1. I was automatically logged out and redirected to the login page within 5 minutes after logging in;
  2. The auto-logout was more frequent when editing notes;
  3. I have tried adjusting Chrome settings (e.g., allowed pop-ups, disabled ad-blocking extensions, tested in incognito mode), but the issue still persists.
  1. To maintain a stable session after logging in, with timeout logout only after at least 30 minutes of inactivity;
  2. No auto-logout due to frequent operations while editing notes.
  1. I have ruled out possible causes such as unstable network, browser cache/Cookie errors, and cross-device login conflicts;
  2. In Chrome’s site settings for web.bear.app, “Pop-ups and Redirects” has been set to “Allowed”, while “Intrusive Ads” remains “Blocked” – I’m not sure if this is related to the issue;
  3. The Bear native app (on macOS/iOS) works normally; only the web app has this problem. Hope it can be fixed soon to resume my workflow.
Hi, thank you for the very detailed report and feedback!
To clarify, you’re experiencing being signed out of the session after a very short time, even if you were actively editing the notes. That’s certainly unexpected.
If you have the opportunity, could you verify if this happens on a different browser? If it doesn’t, it could be a browser extension that is somehow interfering with the session handling.
In the meantime we’re investigating the issue.
Hi there, thanks for looking into this! Just to follow up:
The automatic sign-out happens randomly—sometimes while I’m actively editing notes, other times shortly after logging in.
I’ve tested it on multiple browsers (Firefox, Edge, Vivaldi) and the issue persists. I don’t have any extra extensions installed on any of them.
Please let me know if you need more details (like my OS version, device info, or error logs) or if there’s any further step I should try to help troubleshoot.
Hello, I recently encountered the same issue on my device. I have tried both Microsoft Edge and Google Chrome, yet the problem persists across both web browsers. I would be grateful to hear if you have any further solutions or workarounds for this matter.
Operation system: Windows 11 24H2
Web Browser: Google Chorme 143.0.7499.110
+1 on this issue. Even when I’m just browsing the notes, it sometimes logs out automatically.
+1. I have the same issue, and auto logout only after 10 seconds when I logged in. In Safari
hey guys,I have solved it。 You can try first fixing your MAC Adress by using terminal(search on AI how to do it)。Second,Network → Dedicated agent: Shut down。Good Luck
