can I use tags to manage my note like I did in bear?
or can I hide markdown notation in bear?
Hi
Panda will soon be the editor of bear. so the answer is: yes! ![]()
Panda Check-in: Integration, Search, and Todos - Updates - Bear Beta
Hi there,
Panda is just the test version of the new editor for Bear. So when Panda is merged into the current Bear via the 2.0 update, tags and all Bears features will still be available.
After the merger Panda’s current features (including hiding markdown) will also be available to use in Bear.
At the moment Panda is just being used for testing.
