I’ve updated Bear and also iPhone to iOS18 but I can’t find the Control Centre Widgets. Whenever I search for Bear widgets, I get nothing.
Once in control center, look for the “+” in the upper left-hand corner and press the “+”.
Then look down at the bottom of the screen to see “add a control”. Press “add a control”; Bear was the first section in that list.
I’ve been doing that. The first section in my list is Capture. Ah well…I’ll keep trying, I guess. Thanks for the response.
