Testing version: Version 2.0 (10084)
What were you doing: I created a link to another note in the same subcategory
What feature did you use: wikilink
What happened: Upon typing the note’s header by using part of its title, Bear seemed to find the note and created a wikilink. When I clicked that link, Bear created a new, empty note with the title of the link.
What did you expect to happen: I expected the existing note to be found and see a backlink in the backlinks section of the Info panel.
