Understanding and appreciating that Bear has better way of folding headings and bullet points but on mobile it seems it’s still not convenient because I have to turn on toggle side actions first.
Although I can keep it on all the times, when I scroll my note to the middle (say the 5th heading) and switch to other apps and go back, it will scroll back to somewhere like the 2nd heading, until I turn off toggle side actions.
Will you follow the way of Apple’s doing in the coming ios 18 that folding option shown when I tap that heading?
I found there are good functions on Bear. Mac’s user experience is perfect but my user case is more iPad/iPhone than iPhone so I found a lot of small but annoying bugs, or something that can be better.
For example,
- images are sometimes small and sometimes the full size.
- not all the text selected are copied successfully (e.g. when I try to copy “I am too good to be true”, the result will be “I”)
- returning to the previous notes on iPhone needs two hands, or turning on toggle history navigation, while I think we can follow the way of iA Writer.
- quick open is useless on iPhone with three fingers
- will ram management be better? Because when I go back to Bear, it always shows the red home screen and toggle history navigation are cleared. (Or automatically go back to the note list)
I hope to switch from Apple Notes to Bear. Yes overall is great but there is much room for improvement on iPad or iPhone version. Now I use Apple Notes mainly and sometimes will need to use iA Writer.
