Images in exports not = to editor view
  • Lettera Version: 1.0.0 (4458)
  • macOS Version: 27.0.1
  • What were you doing: exporting to PDF & ePub
  • What feature did you use: File->Export
  • What happened: images lose position and size as defined in editor & callouts not rendered in ePub
  • What did you expect to happen: export would mirror editor view
In the Lettera Editor I center the images by using Tabs and/or spaces and in many cases I resize the images as well. I seem to recall in some of the earlier versions the exports rendered the images as they were positioned and sized in the editor but I could be wrong. Currently, the images are being positioned at column 1 and the full size image is depicted, not as defined in the editor. Since I’m able to center and resize the images I assumed they would be exported the same.
The Markdown spec states:
A code block in Markdown can be created by indenting lines with four spaces or one tab, or by using three backticks (```) or three tildes (~~~) to enclose the code. Additionally, you can specify a programming language for syntax highlighting by adding the language name right after the opening backticks or tildes.
Since I am using the tab for images and captions below the images they are being treated as “code blocks” in other apps like Marked, One Markdown, & Markdown 3000. The Lettera exports do not treat them as “code blocks”.
Do you have a position on how you’re going to be handling the markdown that I’m creating with Lettera? I want to adjust my writings per your direction.
In addition, I noticed the Callouts are being rendered correctly in the PDF exports as depicted in Lettera but they are not being rendered the same in the ePub export.
I’m assuming this is a bug in the ePub export.
thanks -tom
