Outline window is drifting away
  • Bear Version: Version 2.6 (13715)
  • OS Version: MacOS 26.0
  • What were you doing: Typing my notes
  • What feature did you use: Poped out outline window
  • What happened: The outline window is sinking down as I change my document.
  • What did you expect to happen: The outline window to stay where I put it.
Video link: Proton Drive
I had a very similar issue happen and was able to identify and reliably reproduce the issue HERE but I don’t think anything has been done about it yet. Long story short if you pop out the info panel when it’s NOT on the table of contents, and then switch to the TOC pane it doesn’t cause that issue.
