Panda is not showing text
Panda doesn’t show text in Welcome to Panda Mac window. It only shows table.
I have attached screenshot.
Thanks for reporting this issue. Do you mind telling the Panda release you are running?
Of course, it is: Version 1.0 (3147)
It might be some old version, because I wasn’t able to find anything newer.
Thanks!
You can find the latest update here: Panda update - new beta available now!
I was using that download. I found on that post that another user had same problem:
oh yes, there was an issue with the build. Please use the same link to download an update release.
Thanks, I got it. Now it’s good!
when I open the file it doesn’t show the wlecome text, I downloaded the most recent beta
Hello, a new update addressing this issue should be available.
It worked thank you so much!
I have the same issue on version 1.0 (3151).
The text is there, because I selected all, copies as Rich Text and pasted it on Apple Notes and it shows-up there.
