Remember Me Checkbox Does Not Work to Persist Session on Same Device
Operation system: MacOS 15.5
Web Browser: Chrome 138.0.7204.101 Official
What were you doing: Trying to access Bear Web in Chrome
What feature did you use: Log In
What happened: Every time I open Bear in a new tab, I am asked to log in which is cumbersome considering the two-factor Apple Auth.
What did you expect to happen: I expect that when I check the “Remember Me” checkbox I would be given at least a 24 hour session where as long as my cookies or localStorage were not cleared, I would be able to access my Bear instance again without logging in.
Feedback: The overall editing experience feels great, but this login issue is very inconvenient. Overall, this is a very impressive Beta release and I will continue to use it, however, it would be AWESOME to get this login & session issue resolved.
I also am experiencing this in Chrome
Have you flagged the “Trust this device” option in the top-left corner of the webapp?
Wow. That does it. That setting should really be front & center after a new login. Thanks!
