Requests about folding (2)
The toggle button kind of confuses the hierarchy
since the button is on the same vertical line, although it has different hierarchy
so, it’s quite confusing when it’s like this
When I fold it, it comes like this.
I hope there is a more intuitive looks for distinguishing the hierarchy
The big disadvantage of the solution you present in the screenshot is that the information is hidden in the gutter. And permanent visibility of the information is not really ideal.
Nevertheless, it is actually difficult to recognise the hierarchy at first glance, especially with the headings from level 4 to 6. In fact, it’s impossible to see it unless you place the cursor in the heading.
I once suggested autonumbering on a per note level for this purpose which I actually consider as perfect. Different coloured headings would also be a possible solution. Which solution would actually be the best for bear, I trust the developers. They would come up with their own idea, provided of course that they recognise the problem
