Super strange rendering glitch when using Bear on external screen
  • Bear Version: Beta Versione 2.2.3 (12777)
  • OS Version: 13.6.6
  • What were you doing: Opening a note after switching from another tag
  • What feature did you use: Selecting a note from the notes list within a tag
  • What happened: The note text appears mirrored bottom up
  • What did you expect to happen: The note shall be properly rendered
The problem occurs only on the external screen (A benq 2k connected via hdmi) when selecting a tag and then a note from the list. If other notes are selected (or the same one at a later time without switching tags) the problem is resolved. A video is a better explanation
It sounds like a strange bug you’re encountering! The note text appearing mirrored and bottom-up definitely isn’t expected behavior. Given that it only happens on your external BenQ 2K monitor when switching tags and selecting a note, it could be related to how the display handles the rendering process.
A few things you could try:
  • Check if the external display settings (resolution, scaling, etc.) match your OS settings.
  • Ensure that your HDMI cable is securely connected and try switching to a different cable if possible.
  • Test if the issue persists with another external monitor or port to rule out potential hardware conflicts.
Sharing a video would be helpful for the developers to diagnose the issue. It might also be worth reporting this directly to Bear support if you haven’t already, as this could be a display-specific rendering bug in the beta version.
Hope this helps, and good luck getting it resolved!
