Toggling nested tags closes sidebar in IOS (iPhone not iPad)
  • Bear Version:
  • 2.3.12
  • OS Version:
  • IOS 18.3.2
  • What were you doing:toggling opening nested tags
  • What feature did you use: nested tags
  • What happened: on first use, instead of the toggles opening nested tags below, the sidebar closes to show the notes full-screen
  • What did you expect to happen: the nested tags should appear without closing the sidebar
  • After this has happened once per session, toggling nested tags returns to correct operation
  • nb This problem only occurs on my iPhone, not on the iPad.
